having some a/c and other problems??
ok so the other day i was trying to make my a/c work and hooked up a hot wire from the fuse box and ran it to the a/c compressor and it worked because the compressor would not turn on if i just pushed the button dont know why would love to fix. i slipped and hit the hot wire on a peace of metel and now my a/c light will not come on and my floor and all those buttons will not change and i cant adjust my mirrors must be a fuse from what i can think of but i dont know were it would be i cant find it?? please help its getting very hot for no a/c the next question is what if you dont replace the dryer after it has been open will it still work ??
thanks
justin
You may wanna check the fuses under the hood. There on the passenger side in a black box near the firewall. Check the big fuses I think one is 50amp and the other it 40. Look in the top through the clear plastic and see if their blown. Also check the others. Check all fuses just in case.
ok well i figured out where i was leaking so i fixed it and had it charged and now still when i push the a/c button the compressor does not come on so i ran a hot wire to it to 12v and a switch but the next problem was my fans dont come on with the a/c and it does not get cool and then the idle goes from 750 to 450 and back and forth like that i dont know why can someone help
thanks
justin
lol
i had the sam problem :bang:
i charged it up the compressor would not run . ran some test on the compressor and found it was not getting a ground. i look at the wiring diagram and found out it could be the switch. and what do you know it was the switch i went to the junkyard and got a couple… lol
p.s that ac is cold brrrr…i gotta swich for sale 20 shipped.
