hazard lights??????
Hey guys I’ve got a quick question. My hazard lights won’t turn on when i push in the switch. I really dont know what it could be. All I know is when I turn on the turn signal to either go left or right and then hit the hazard swtich they stop to blink altogether. Please help.
check fuses by your leg? you can also pop out the buttons to see if anything is wrong with a flathead screwdriver
if theres only one fuse by my leg then i checked it and it seems to be ok so i dont think thats the problem. Unless there is another fuse which i dont know about.
Any other ideas guys???
Originally posted by Rockstar1129
[B]if theres only one fuse by my leg then i checked it and it seems to be ok so i dont think thats the problem. Unless there is another fuse which i dont know about.
Any other ideas guys??? [/B]
our cars have 2 fuse boxes. one by your left leg (there is more than 1 fuse here… more like 20 or so). There is also a fuse box in the engine compartment…pass side…can’t miss it. If i’m not mistaken the hazard fuse is in the underhood fuse box. check that first, if its not the fuse…maybe a bad switch, test that. If its not a bad switch it may have something to do with a bad relay or something somewhere…i’m not sure. you’ll have to look at some wiring diagrams if its not the fuse or switch.
Do your indicators still work?? Because they shouldn’t if the Hazard switch is in fact faulty.
well lets say i hit my turn signal to make a left turn and then right after that (while its still clicking) i press the hazard button and the turn signal stops to click. If I hit the hazard button to turn it off the turn signal continues to click like before.
