Hazards and Cruise Problems?
I have a 91 GS and for some reason cruise control will not click on. The button works because I can see it light up but the buttons on the wheel do nothing. Also my hazards dont work. When I turn the button on nothing happens other than the fact it will make it where I cant use my turn signals. I have checked all the fuses and dont know what to look for next.
for the hazards go to your engine bay fuse box and make sure the white/green wire isnt cut…if it is then thas your power wire I believe for the hazards…mine was like that and then it started working after I connected it
for your CC check by the brake and clutch pedal. there’s 2 plastic button on it if one is missing ur cc wont work. u just have to look under the kick panel and there should be 2 CC relay. your clutch and brake pedal should be hitting it. there should be 2 plugs on there. if it’s gone just replace it like i did. i just put a 10mm bolt and nut, and covered it up with black tape and wa laaaa… it should work.
