Head gasket?
I’ve pulled my motor apart for the second time now. i had a little oil leak at the head gasket where the dowel pins go. the first time i pulled the head i noticed antifreeze rust spots in cylinder 4. i resurfaced the head and the block. i got new valve seals and guides. complete valvetrain upgrade. the same happened now even after replacing the seconds oem head gasket with a new one and torquing everything to specs with arp hb. i smelled anifreeze burning and had white smoke coming out of the muffler. i would see smoke when i punched it or hit vtec but only for a couple of seconds. the problem persisted after the first rebuild. i dont want to put everything back together until i can diagnose the problem. what could it be? what should i do?
Im assuming you resurfaced the head and the block? If not that is more than likely the problem… One or the other is warped.
If you did resurface both the block and head… Im stumped.
How sure are you that the head gasket is actually leaking oil? Oil leaking from the head gasket is really rare. However what is extremely common is leaks elsewhere dripping down the head and pooling where the head and block meet - making it look like the head gasket is leaking oil. I’ve had this happen to me numerous times and seen it numerous other times.
id def get the head and block decked…and idk how much oil u was coming out of the head from the dowel but every honda ive seen seems to dribble out there a LITTLE not much but some
