Head gasket
Hi guys,
It looks like I have a blown head gasket and am looking at replacing it myself. Local shop wants $1200 - $1300.
Where would I find a good step by step thread / instructions for a 1991 Acura Integra GS head gasket RE & RE?
Thanks in advance,
J
At the minimum you really should get a Haynes manual from your local parts store… best thing would be for you to find a copy of the actual Honda service manual online.
Just found the Honda Service manual online and it has a lot of good info, thanks for that tip!
Already have the Haynes manual but thought there may be a good thread or link that someone has used successfully in the past.
J
I’d definitely use the Honda Service Manual as far as the general procedure and definitely for the torque specs.
Most walkthroughs will be the OEM procedure, just re-hashed. I definitely wouldn’t trust online torque specs without double and triple checking. Proper torque specs and torque-increments will make or break a headgasket job.
