idk if this thread belongs here but help me out!
im wondering if the headlights are adjustable…
…i know the fogs are but i can’t find where you adjust the headlights!!
my lights look OFF
here’s how it looks like:
see how the left side faces up more than the right?
its hard to tell considering that picture is not facing str8. but take out your bumper and I believe you can work with them from there. Cant quite remember but you’ll see.
[QUOTE=naes;1904901]ooops but see how the left side is brighter than the right?
that’s what i meant
but any suggestions on how to take out the bumper?[/QUOTE]
yeah I can kinda see that. first take out the side screws on the side brackets and then take out your bumper lights and look inside (there is a screw in there) I think is 12mm, have a friend to help you hold one side until you take out the other one.
Looks like you have the USDM headlights am I right? There are several long screws sticking out of the back of the housings. These screws are connected to a set of teeth encased in a plastic housing held down with two screws. You can turn the teeth adjust the angle of your headlights. Use a phillips head screwdriver to turn the teeth and adjust the headlights. Hope this helps.
[QUOTE=naes;1904917]side brackets?
what are the side brackets?
do i take out the corner signal lense to make it easier?[/QUOTE]
look straight into your wheel, then turn your head 90 degrees and you’ll see the screws. then take out BumPer Lights and look straight inside you’ll see the 12mm? bolt (total of 2). that is it. I recommend you get a manual, they are cheap in egay ($7) it will be really handy.
