I need to know where they are. I’ve been without my G2 teg for almost two years now, and I’m trying to help a friend long distance with their headlight issues. Fogs will not turn on, but the light on the fog switch works. Also, just switched from the clear eBay headlights, back to OEM, and the headlights only work on high. All fuses are good, and switches/bulbs appear to be good as well.
If anybody could let me know where the relays are to help her, I’d much appreciate it. Thanks in advance.
There is no relay for the head lights, there is one for the fog lights.
Power for the fog light switch comes from the left low beam fuse, [fuse 4 - 10A] as long as no fog light wiring has been modified, if fog light switch indicator turns on, left low beam fuse must be good, [right low beam fuse is fuse 3 - 10A].
That would also mean the head light switch is good, [including dimmer switch]
Sorry I am not sure where the fog light relay is in a G2, have you checked the fog light fuse, fuse 19 - 15A, [in under dash fuse box?
I would also recheck the wiring at the head lights. 94
maybe the wiring got reversed or something on the headlights? but…
regarding the fog light relay, its in the top right corner of the icu. its near the dash harness connectors on the top right corner. i believe a 4 wire harness plugs into it. i believe mine is shot at the moment, and gotta replace it.
note: i posted not knowing if this has been resolved.
