Headlight Help.
I’ve had my DA for a while now, been registered here for a little while now too, and I’ve had this problem since day one, and I figure I’m about ready to start looking into fixing it…
Basically my problem is with my passenger headlight, I don’t know if it has to do with the light itself, or the wiring to the light, but when ever I use the passenger side blinker the headlight blinks with it. The left side is fine… and when I turn on the A/C blower motor, the passenger headlight goes dim, and when I turn on my brights the passenger light goes dim, also on the cluster while the headlight is dim, my passenger turn signal arrow lights up half way… it does this every time, the driver’s side light is unaffected… I’m just wondering if maybe anyone has come across this problem before… I can’t be the first one, I’ve searched before for the answers, but I really can’t find anything conclusive… I’ve checked my grounds and everything is fine… I appreciate your time, thanks G2IC!
sounds like two wires are touching somewhere or maybe a combination switch issue(correct me if im wrong). IIRC somebody had this problem a while ago and i never saw the solution.
here is a wiring diagram for you headlights make sure everything here is correct on ur your wiring.
Check the grounds for the right side lights. 94
This^^
definatly sounds like a grounding issue to me.
