How would I wire up my lights so that the low beams and fogs stay on when the brights are on ?
For the fogs, rewire the fog light switch, red/yellow at switch, [12V+ input from low beam fuse] to 2nd ign. free pin on under dash fuse box.
For the low beams to be on when the high beams are on you will need to wire in a relay on the low beam output, [red/yellow] of the “Combination Light Switch” the question is why would you want that?
If the above is done the fog light switch rewire will not be needed. 94
Thanks ! With the my projector 1piece headlights the brights are not wide spread like the lowbeams so I figure if I had them on along with the highs I could get wide and long ! But now I think I’ll just get HID’s .
