Hey guys so I am putting hid’s on my teg, and they are the ebay ones… i know i know… lol but anyways, i have the projector headlights for now, and i am running into a problem about finding my high and low beam positive wires, i think that on the driver side headlight, the red and white wire is low beam, correct me if im wrong, so does it mean that on the passenger side, it means that the wire on the same spot must be the low beam as well? it is the middle wire in the plug, also i noticed that on my driver side plug, there is no black wire,(ground) the previous owner messed with the wiring, and replaced it with red, so now i’m confused, i have no light testers to see which is ground and power, so idk what to do now,
I put a line on the wire that i think that is low beam and i want to make sure that the other middle side is low beam
Not sure if this will help but I still have the wiring that came with my ebay headlights that I retrofitted.
Thats the plug that plugs into the bulb itself. But on mine the middle one is black. So I assume the middle is ground and the two outer wires are power. But I’m not 100% sure.
