headlights
There is condensation(sp) in my left headlight and not in my right why is this and how can i remove it.
Thanks
First check and make sure the bulb is secured correctly. When I bought mine someone seemd to have had to hard of a time puttingthe bulb in so they didn’t lock the twist ring down and it had let water in which is why I now have to buy a new passenger headlight. Moisture is very bad on the fake silver plastic. If your bulb has a good sel them it is either a cracked lense or housing or the seal around the lens is leaking. So look over it real closely first then check over the seal and see if you see a bad place. It has to be one of those things.
hey i got a reply i will look at that thanks man
When I first put my 1-pieces in i had condensation in them. It was because I had them in the warm house and then took them out in the cold to install them… Just take the big rubber boot off where the head light bulb goes in and they will dry out quick.
If you have USDM lights, I have no idea how to fix it!
