heater / ac will not turn on
i searched… didn’t find anything that matched whats wrong with mines.
since i got the car the dial for the ac (i guess the speed setting) has been stuck on full blast and will NOT move either way, it will NOT blow out any type of air. i know the ac belt is broken, and i’m not complaining about not getting any ac because it’s 50 some odd degrees outside, but will that have anything to do with why it’s not blowing jack shit? (let alone hot air)
maybe i looked over a thread that was posted / answered, and if you know where to point me to then by all means point me in the right direction, but i’ve looked… thanks
ya same problem happened to me, just fixed it. First thing, you need a new fan switch(the knob on your dash thats stuck on full blast) part #: 80410-SK7-A01, check your heater fuse(green box style i think its a 40a?), also check your blower resistor for 12V part#: 79330-SK7-003, and finally check your blower motor for 12V part#: 79300-SK7-A04 this part is way cheaper at autozone though. They might not all be blown but just check those, mine had all been blown though.
where is the blower resistor? is it in the fuse box on the driving side?
  1. Remove glove box.:slight_smile:
  2. Remove two small screws from the resistor pack located on top of the blower.:rockon:
o, you mean that one. I just replaced that like a day ago, but still no fan. what should I check next? Actually, the thing is it would turn on sometimes but recently it just stop working for no reason.
xxfile - Check the blower motor itself, especially if you have that passenger side water leak, both my Integras had the leak and both had the motor and resistor shot.
It’s fixed, was the ignition switch…
