help!!! 1990 Tegra
After I have driven the car for a while when it is above 90 dgrees outside my car wont start it wont even turn over. I just replaced the starter so that couldn’t be the problem because it makes a clicking noise. Is there anything else I could check like the igniter or other things.
Thanks for ya help
90 teg GS 4 door
maybe it’s the main fuel relay…check the teg tips!
how much do they cost??? if you know
I think it was the ignitor that doesnt like hot days. You might want to look into that.
Just do a search for it. This topic has been gone over several times.
Later,
BR
Also another question
my rotor under my cap is really loose is there anyway to fix that or should i go buy another one. It like the bolt that holds it on is to long.
if u know the bolt is too long. then change it. cause i did a cap and rotor change and the rotor didnt come with screws. but if i remember correctly my rotor is held by something like a hex nut. it uses the tool for like rollerblades.
If you buy your rotor from honda it should come with a screw or hex screw.
The 90-91 rotors use the hex and the 92-93 use the phillip head screw.
Later,
BR
Originally posted by B R
[B]If you buy your rotor from honda it should come with a screw or hex screw.
Later,
BR [/B]
hmm wonder what happen to mine then. its not + screw. oh wells. i’m starting to hate screws, always stripping on me.
You dont need to tighten them that much… Too much torque is bad.
Later,
BR
yea search search search guys… the ignitor/ignition coil thing has been beaten to death … it will all come up! :smiley:
My bad, the 90-91 rotors come with the hex screw but the 92-93 rotors dont come with a screw. You have to reuse the old one…
Later,
BR
