Help.. 91 GS integra w/b17 obdo to lsvtec obd1
So after a few nights to think about what I was gonna do i figured that I was gonna head in a whole new direction. I have 2 integra’s… one is a 91’ 2 dr gs with a 92-3 gsr swap… I spun a rod bearing in it… the other is a bone stock 92 4 dr. LS integra with auto tranny… So here is what I decided to do…
Convert my 4 dr. to five spd and throw all my aftermarket stuff from my 2 dr. on it and sell the B17 setup and 2 dr shell… I decided this after my little brother lost the key to the 2 door and basically I just gave up on fixing it up… as I was planning on swapping the LS/v set up in it… but in the end it is a cosmetic queen and I just don’t have the energy to fix it up anymore. SO… this is going to be my new build… I’m gonna keep everyone updated as to how it goes…
So heres to start…
What I’m starting with is a completely stock 92 LS integra, it’s 4 dr and automatic…
The first thing on my list to do is swap it to 5 spd. I’m trying to sell my B17 parts to pick up an SI tranny but unfortunatly I need the car going sooner then my budget allows me to get this particular part rounded up. Though I’ve never done a conversion from auto to 5 spd. I believe this won’t be too hard as i have a complete car to pull from.
second, I have managed to pick up a FULL golden eagle lsvtec conversion kit from fluid motorsports (I didn’t pick it up directly from them, it was merely bought from them for considerably more then I’m paying and has sat in a box in the garage till now) for the ripe price of 300 bucks… It’s got the complete B18C head, GSR intake manifold, all the fittings and lines along with a blox sandwich oil can for oil feed to the vtec soleniod which was also included along with new timing belt and vtec oil pump… Good deal huh???
So the plan is to bolt all these parts on my swapped 4 dr. da.
third (while or before the swap) I’m taking my ls ecu down to speed factory and they are going to convert it to 5 spd settings and then tune it for my set up.
Anyways, this is all kinda out of order but I plan on semi freshining up the lower end also, I have picked up new acl rod bearings, arp rod bolts, and shot peened LS rods with civic SI pistons… so I should be able to up my compression a little bit as well.
as far as bolt ons So far I just have aem cam gears (useless really without cams) and a sk2 70mm throttlebody and some dc headers and straight piped exhaust with RSR muffler that will have to be modified to fit the 4 dr as it’s off my 2 dr.
I also have adjustable coilovers upfront and lowing springs for the rear, oem mud flaps, short shift, and I think that’s it… I’m selling stuff from my b17 set up to get as much stuff for this new car as possible… so I look forward to updating everyone on progress and seeing what you guys think of how it turns out!!!
Jan 1st 2010…
Picking up 4 dr and towing it home to start work!!!
