Help! 93 gs-r upgrade to b18c5
Long story short, i have a type r motor that I got for a steel and i want to drop it in my integra.
i do not know what wiring harness to use to make this car run, i believe the 93 gsr is OBD1, so how do i convert the type r engine to OBD1.
any help would be greatly appreciated.
i also plan to put the b17 in my ek, any ideas what harness i need for this?
You are new so I won’t be a prick. But that information is easily found by searching this lovely database which has an answer to every question you may have. You just need to search, it has been asked many times. Won’t take too much work tho, good luck
Check out the engine swap guide in the Teg Tips section. It’s old but all still relevant. Should have 99% of the answers you need.
and post some pics asap
