my problem is my car overheats dramatically… what my problem is theres no visible leak no where… all i see is steam that comes out of the lower radiator hose… and when i drive my car for about a mile the radiator drains out some where.,the thing is wheres the leak because i just changed my radiator a month ago…could it also be the thermostat…?? i changed that the same time i changed the radiator…??? help please
Check your oil. make sure its not going into it. did you relieve the system of air when you changed your radiator and thermostat??
i found out the problem it was a bursted heater hose… thanks…
