I NEed help quick… please help me out… ok… here it goes… i have a first gen b16a and i just got the dc 4-1 headers…
as you know the headers only have one o2 hole… and the first gen b16a has two o2 sensors…
i want to know that can i splice the 2 o2 wires together to read only 1 o2 sensor… do you know wat i mean…
2 o2 sensors wid 1 wire each…
i take the second o2 cut it and eliminate it completely and the wire remaining, i take that and tap it into the first o2 wire… then i plug only the first o2 sensor in the header… so that the computer now only reads the same o2 readings for both wires…
do you think it will work… please let me know asap…
do you think there will be any check engine lights…
