Help B16a won't start!!!!!!!
I had a shop install the B16a, I transferred the LS Harness over and hooked up everything. The dang thing won’t start. here is what I replaced
ECU
Distrubtor
Plugs
Plug wires
ICM (ignition Control Module)
Coil
Check all the wires from ECU to Distrubtor
It’s a 90 LS
She’ll crank but won’t fire. Dan Can you please help me here.
The only thing I haven’t check was the ground. They repainted my engine bay, and I think the ground isn’t properly grounded. ANy advice will be appericated.:frowning: Please Help me.
My guess would be the ground wire. I had a Prelude once that wouldn’t start and it was due to the ground wire. I tell all my Honda driving friends that the best protection from someone driving off in your car is to loosen the ground wire. BTW that 84 Lude I had and sold to my friend is still running. It had over 200,000 miles on it when i sold it and hes had it for 3 years with no engine problems. Hondas are made to last!!!
fuel delivery problems maybe? I had to “cut&paste” the line that goes from the fuel filter to the fuel rail and use the original integra for the filter and the b6a end for the rail…or tery using some starter fluid…spray it in the throttle body.
It was the ground wire on the wire harness wasn’t grounded. Thanks Jetsped!!! Thanks everyone.
