well i just rewired my front bumper lenses with a crappy switch (no fuse), and today i look outside, and my brake lights are permanently on.
hopefully i didn’t mess anything up by wiring up this switch… but this is the deal with the lights…
when the car is off the brake lights are on, i would suspect a problem with the brake pedal itself, but i’m pretty sure that the lights don’t get power when the car is off, hence they shouldn’t be on
so i disconnected the fuse in the engine for the stop/horn, which, for the teim has stopped the problem. but i have no brakelights.
if somebody could help me out i’d be really appreciative
check on your brake light switch, it’s located on the upper part of the brake pedal. not exactly on the pedal itself, but on a bracket in front of the pedal.
