HELP Car won't start after charging battery
Whats up G2IC, I’ve been having a nagging issue for about a week now. My car won’t start after charging battery… the motor won’t even turn over. I made sure battery were connected to turminal but engine wouldent even turn over. Guy at autozone told me that it could be my starter. I heard something about a starter sticking, not sure what that means. What’s strage is if someone gives me a jump it starts right up and dosent shut off. The only way to start my car is to get a jump or pop the clutch. I have noticed for the past month that when I turn my key to start the motor it dosent do anything untill the thrid try. Please help. Guy offered to rebuild my starter for $100 labor included. Please help!
U need a new ignition.
check your grounds, battery terminals clamps first… believe it or not a worn out terminal clam on the negative cable can cause a myriad of issues as can a loosely connected ground.
after I’d suspect an ignition switch.
