i just changed the fuel filter, the car started then died. sounded like no gas. i added about 3 or 4 gallons, gas not the problem. the car was fine until i changed the filter. the in and out lines are on the right ports, no fuel leaking from the lines. i did however, forgot to plug in the 1 and 3 cylinder plug wires when i first started, i plugged it back in after the engine died and now the car wont start. the pressure is still around 40-43 psi. the engine is still turning.
the new washers are a lot smaller then the stock ones, so maybe the hole is now blocked on the banjo bolts.
could me not plugging in the 1 and 3 plug wires have caused the cap or another part of the ignition to malfunction?
i’m gonna try putting on the stock filter and see if that works, let me know what u think, thanks!
