Help! Clutch engagment point too low!
Help!
I have read many posting about adjusting the clutch cable but I am confuse. One member says that adjusting the clutch cable only give the pedal more free play and doesnt adjust the engagement point.
My clutch grabs fine but its hard to put into gear without pressing all the way down. Engagement point is way too low! I’m not use to that. I do have 2inch free play before u feel the resistant. Pressing on the pedal more than 3/4 ways down is where the engagement point is. If its the clutch cable that can help put the engagement point at half way point than great! if not then how do I adjust that or do I need a new clutch (which I dont think it does)
Thanks in advance!
im not to terribly experienced with clutches but i would say it could be cable adjustment, possibly a worn/stretched cable, or maybe even throwout bearing…those are the things i would personally try first…in that order
