I am getting a constant stream of air coming out of the breather hole…I mean a good amount of it aand it is constant. Feels like when you blow air from your mouth to the back of your hand. I just replaced the pcv valve so I was wondering if any of you guys know what the problem is?
Also I am idling extremely high, like 2k after car is warm. I think this is the IACV problem, but will this cause the breather hole to shoot out air? Along with the air, when i press on the throttle a good amount of oil shoots out as well.
BTW, I just changed out my JG cams and put in GSR cams and redid the valve adjusment and timing belt. the intake cam gear is a bit advance cmopared to the exhaust. I mean intake is pointing at roughly 56minute while exhaust is at 0. I must have splipped putting on the belt, but will fix it later on the week.
The thing is, it wasnt doin that b4 the cam swap.
TIA
Ken
