The light comes on very dim and is more noticeable in the evening. Can’t quite tell if it is me or the temp outside. Oil level is fine, tried replacing pcv and that helped a little, but not much. Is this maybe a head gasket ???
check your oil pressure, you have to get a tester gauge or just install an aftermarket gauge, it’s on the Turbo Guide
