Hey guys I have indiglo gauges in my 92 GSR and now all of a sudden the fuel needle is stuck at full. Anyway I can remedy this?
probably the piece of the indiglow on the fuel gauge part is sticking out and pressing against the needle causing it to get stuck, all u need to do is press back the indiglow gauge and make sure it’s not pressing against the needle causing it to get stuck, alot of double sided tape should work
alot of people (me) have broke their gas gauges or temp gauges puting on indiglo gauges… there is like tiny thinner then hair copper wires on the back if one gets jacked up your screwed…
when you put them in did the gas go up to full but never go back down… thats what mine did
I would love my needle to be stuck on full all the time-- that means you will never run out of gas!
Is their any way the fuel gauge needle be fix from being on full or do i have to replace it
