HELP Going 91 to a 93 front bumper
So im having so much trouble trying to put the 93 bumper on my 91 Da. First problem was my reinforcement bar for the 91 didnt want to fit the 93 bumper so then i got a 93 reinforcement bar with supports. I was able to actually put it on but the sides where the 2 screws by the tires go in looks way off, there are big gaps. Just looks funny all together, I dont know whats wrong if the bumper is twacked or what. Can I get advice from those of you who had similar problems or any input I would really appreciate it, THANKS.
I put a jack and lifted the bumper up aligned the bumper and the tightened the 4 front support bolts behinf=d the bumper lights
That’s weird because the only thing i switched to put the 92-93 bumper on my 90 was the styrofoam. I didn’t switch the bumper support
I think the bumper is probably the problem im going to get another one and go from there, thanks for the feedback.
G/l
try this
http://g2ic.com/tegtips/exterior/13.html
Just did mine today. All you have to do is keep shaving down the styrofoam. Just check where it’s hitting and carve it up with a box knife. Good luck.
i was under the impression that the mount “blocks” and the support styro and actual bumper cover all had to be cahnged to do the swap?? am i misinformed if i am thats great lol cause i need a new bumper cover since ever one of my mounting tabs was cut off
