Alright First Thanks For Looking At The Thread… Heres My Problem… I Have A 93 Integra With Stock B20… Only Upgrade Is Cai… My Problem Is That My Car Starts At Low Idle… I Cleaned My Iavc (behind The Throttle Body) And Still Feel Likes Its Going To Die Untill I Warm It Up. After That When I Throw It Into First And I Try To Go It Boggs Like Crazy And Makes My Car Jerk, And Happens In Almost Every Gear. When My Car Is In Neutral And I Rev It, Seems Like It Has Trouble About 2.5 To 3 Grand. Also It Just Threw An Check Engine Code Last Night. Some Of My Friends Said Throw Some Fuel Injector Cleaner And Some Say Its Possibly 02 Sensor. If Anyone Can Help, It Would Help Out Alot.
http://www.g2ic.com/forums/announcement.php?f=29&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
