i wanted to know if coil overs from a 98 hatch would fit in to my 91 teggie. i think the coil my friends giving me are skunk 2. please let me know. i really need your guys help
no they won’t fit, or properly that is… the rubber caps, or tops that the springs use for a 94+ won’t fit the 90-93… you’ll end up causing problems later on down the road… and don’t try to use civic one’s, the spring tention is softer and you will be riding on the bumpstops even if you cut them… just go out and get some springs for the 91 teg… they are only like 300 anyway.
