so i got some pwjdm window visors but i cant figure out how to make the clips hold on to the car.
they go under the rubber I think Isport has a write up he can send you thru email you should ask him
alrite ima have to ask him, wazz up man? u trying to sell ur car??
if i get the price i will lol the visor are not hard the metal clip goes under the that rubber on the window seal
i still cant get the clips on. can any1 help???
I have a set of instructions that i can email you that came from isports version of cf visors. My email is dpintos382@yahoo.com
hey jdm_livin i installed those took me like couple of hours to measure eveyrthing and install them…but you pull the weatherstripping down and then put the clip in there…pay close attention to how the clip goes it can only go one way…it will sit flush agains that metal lip inside…if u try fititng the other way it will just look weird…and then mount them and 3m tape it…thats all
thanks CG5accord but i put them in on saturday already… haha the 1 thing you mentioned that no one else did to me though was TO PULL THE WEATHERSTRIPPING DOWN hahah every1 just said "it goes in between the weather stripping and the hard trim… so im sitting there trying to force the clip in hahaha. untill i just said fuk it and pulled down the stripping. and wouldnt you know it, the clip sat inside the metal trim perfect.
ahaha no problem…man sorry for the late help ahaha
Just installed mine to try and stop all the wind noise coming in through my bad window weatherstripping that i cant find replacements for.
What no one says here is to drill holes in the clips and use flat head screws to hold the clips in the track that holds the weather stripping in. 20 year old weather stripping is not going to hold those clips in. Amazing whoever built these didn’t include instructions on how they want them installed, not to mention they could have used the screws that hold the metal weather stripping channel to the door frame and made everything a lot easier.
post pics!
i have the PWJDM ones too…already installed the but they aren’t installed the way i seen oem ones …obviously they’re not oem but i figured they should mount they same, no??
