help i cant fuel!!! car wont start
hey guys thanks so much for stickin with me and bryan, i am sure i can speek for him when i say you guys are life savers. gstring i know that i would like to check the coil but the reason i ruled it out is i have spark but i spray no fuel into the cylinders, i took out the injectors and held them into the rail and cranked the engine the one i wasnt holding in very well came off and fuel fell into the enigne and it started! for 2 secs then died cause it had no fuel i held again all 4 and got no spray so i have got it down to fuel, i like the relay and resistor idea will get back to ya later
stick with us
if ur interested i will sell you my spare, injector resistor box.
-Toby
is it in workin condition? how much you want? if its right i might have ya fed ex it so i can drive again hehe
$50 sound good?
-Toby
k guys, this is it!!! my reply from hell. finally figured out, and she LIVES!!!
we narrowed the prob. down to the distributor wiring. because i went ls/vtec, i had to rewire the gsr dist. wires into my existing ls plug. so , i figured, ls wire colors=gsr wire colors…wrong! the three sensors inside the distributor had to be wired up correctly into the car’s plug.
was not: fuel problem, or spark problem. i did try the injector resistor box with a new one, and tried a new main relay.also tested the dist. sensors. which read between 350-700 ohms. so, if anyone else is having problems with this sort of thing, lemme know. i have the wire colors written down.
we just completed the initial break-in run, so i’ll let everyone know how it goes after that:)
bryan
haha **** bryan i did the same thing but i used the non obd vtec distributor and cut the wires and spliced them together
i gues we know the prob
you are the man
i will try it out and if that don work i will let ya know if i am interested ixtlann
thanks guys way to go bryan!!!
email me @ i1justincredible@hotmail.com with all your info man
later
justin
no we found that out, obd0 and obd1 distributors have different settings and will run the ecus crazy and not match with the wires, we found that out with bryan and i tried to use obd0 on obd1 and failed. but i will buy that distrib of you if you want to get rid of it…
email me
later
