:bawl: I have everything wired correctly, the harnesses are good, bulbs are good, the switch is on, fuse is good, but still no power comin’ through to the fogs. Someone plz help…
are u sure that u have wired it correctly… it may be that or yur bulbs… or it may be yur h3 sockets… then again u can check this wid a 12 V test light… HTH
I tested the power and ground w/ a test light and got both grounds, and when i turned the fog switch off it turned into both power.
u got me lost???
