Help Me Big Problem!!!
Got a JDM b16a from Japan, On the fuel rail they CUT the hose that connects fuel rail to fuel filter. WHAT part should i get to fix this please help me DAn or anyone. The Ls kinda fits but not sure on use, can anyone help me please. Thanks in advance.
Kincaidintegra
Your stock one from the B18A should work fine.
EDIT: I had no problems using a stock 93 LS fuel line and attaching it to a JDM 2nd gen B16A fuel rail.
Simple problem requires a simple solution.
1.) Buy a fuel line for a 92-93 GSR which will run you about $60 or so and will most likely take about 4-7 working days to receive.
2.) Use a dremmel or other cutting tool to cut the coupling that surrounds the house end at the B16A fuel rail. DO NOT CUT THE PIPE ITSELF! Remove the existing hose so there is only a pipe hanging off of the fuel rail inlet. Do the same for the adapter for your LS fuel hose at the fuel filter side and cut the coupler off and strip the old hose off. DO NOT CUT THE PIPE ITSELF! Go to a local autoparts store and buy about 1.5 feet of 5/16" ID FUEL INJECTION hose and FUEL INJECTION clamps which will run you a total of about $5.
The LS fuel rail will not work, nor will the complete hose since it’s shaped pretty differently than the B16 rail.
:confused:
I had a b16a1 used the same one on my LS I just put back in…no problem.
Josh
well the old fuel line from the ls motor, fits, there is a then space for the heater return line, but it will work till i buy a new fuel line and fuel rail, thanks all.
