When I went to adjust my ground control coilovers the allen nut/bolt stripped on the first turn, now I can’t adjust them until I get the nut out. Hs this happened to anyone else, or does anyone have any ideas of loosening the nut before I have to cut it out?
You already posted this!
http://www.g2ic.com/forums/showthread.php?t=165724
http://www.g2ic.com/forums/announcement.php?f=30&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
