I have had my abs light on for a while now and cannot figure out whats wrong w/ it. I have checked all the fuses but i dont know how to check the relays.
This light activates as soon as i take off.
I had the same problem. Looked at the brakes and everything but couldnt find nothing. Then i took it to a shop. the thing i was missing was low on fluid lol. how dumb of me. try checking that. either then that i dont know. good luck
Did THat
Checked the fluid levels already, I even checked the wiring that goes to each wheel. No results yet
i had the same problem before and its funny, it was actually my altenator.Maybe have that checked as well
Ya i’ve had that problem too, it was also my alternator, but might wanna check if your breaks are not sticking in the back that would defentily make it go on.
If you really have a problem with it just take the light out
well if thats not the problem. i wouldnt know then. but i still drove with the light on. i didnt really care as long as there was some sort of braking to stop me.
Okay…so the light won’t go off. What I want to know in order to help you out is did you do anything to your car before it turned (have anything replaced…etc?) or did it just turn on all on it’s own. Any other symptoms? Does it brake funny? My ABS light was on for the longest time and the cause was a bad ABS sensor ring on the axle. If you had your axles replaced recently or hit a rock that damaged the ABS sensor ring, that could be your problem. The ABS pump is also notorious for going out after a lot of years. Hope this helps.
Sorry, i have not paid attention to my post but i think i know what it is. I just recently changed my axles, so i think check that ASAP> Thanx for your help ill keep u posted
