Help: My Oil pressure warning light is flashing
That happens several times already.
And I check the engine oil level using the long little stick thingy that protrudes into the engine and seems like the oil level is fine. Besides, I got an oil change less than 1000 miles ago.
Anyone knows why?
Thanks
If you have oil and the pressure light is blinking, then put a gauge on to check the pressure to see if oil pump is going bad
So How do put this gauge in??
How much does an oil pump go for?
Newbie here.
Thanks.
Ok, I found out the answer of my questions above.
But now comes another one…
If the oil pressure is okay…hopefully.
What gives then?
Thanks
