Help Needed
Ok. I have a 1992 integra which is idleing low and bogging. So i disconnected my o2 sensor. But first i took it out of the manifold. but i but it back and only the wire is disconnected. And i was woundering if driving it around like that would mess up my engine. because no one has them in stock and it has no power when connected. also after reinstalling it into the manifold it smells like bad fish or like my clutch is slipping. is this related to the o2 sensor being disconnected. and it feels like my car is holding back around 5-5.5k Rpms. Can some please help me out. Thanx in advance.
Take a deep breath, collect your senses, and please retype this in coherent sentences. :slight_smile:
TTT Edited
are you sure it’s your o2 sensor that’s bad in the first place? i would guess that running with a bad o2 sensor is better than not running one at all… :confused: you should definitely not run your car hard and replace it asap.
when was your last tune-up?
i replaced my o2 sensor and that helped but come to find out the a$$hole that put my new axle on didnt bleed my brakes and the are grabbing and wont let got
why would he have bled the brakes when he replaced the axle???
