Help, No A/c but everything is hooked up
I put on a new idler pulley for the A/C Condensor. When i turn on the A/C I get no cold air it’s kind a lukewarm. And Does a light come on saying A/C is on?? This is my first Integra please help
whta should i do???:frowning:
needs a freon recharge probably. there is a little glass you are suppose to look in. i snatched mine out (complete A/C) but that is most likely the problem.
Isn’t ther e alight to show the system as being on?
Yeah you’re right it eeds freon, But isn’t there a light to show the system being active??
the same button you push to turn on the A/C has a little green light on it when activated.
The A/C Light
Can it burn out from old age?? How would i replace if if it is burned out
I don’t know if that light burns out from old age, but when mine wasn’t coming on it turned out the switch itself wore out and I needed a new one from the dealer. Once I popped the new switch in, the light was bright as hell and no more lukewarm air!!! The switch is about $30 at the acura dealer. They keep em in stock cuz apparently this is about the time they need to be replaced.
BTW, a bad switch WILL CAUSE your condensor to overload… as it did mine. But luckily there was no damage.
Thanks
Thanks for your help!!
