Help..oil leak next to valve cover!
There is an oil leak to the left side of the valve cover. It looks like it could be coming from some type of cap or somthing. Does anybody know what it is and how I can fix it?
If you want IM me: punisherckj
Could be your valve cover gasket.
:search: Someone posted the exact same question yesterday. It is the cam seal plug. It needs to be replaced. buy an STR unit from Summit they last longer and seal better than the OEM honda/acura part.
cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal cam seal
Anyone found a place to order them?
Options Auto Salon is Out of Stock
Autospeed Racing no longer carries STR Caps
get it from you local honda dealer…its like 4 bucks or somthing…
i just got one and it was cheapp you might wanna also get the valve cover gasget…and all the other washers and goodies…if you are missing any.
later,
dan :stuck_out_tongue:
SEARCH
I may be able to help some people get STR Cam Seals, I know a guy who has 5 of em. They are in the orginal package, and have a crown above the STR logo. Email if your interested.
embalmer@bur.adelphia.net
yea whatever you do dont get the stock cam seal :down: its worthless get a STR one…from what i’ve read thats one of the b-series engines weak link. :tsk:
CK, remember at Magic Mountain, I told you it is the cam seal.
Yea, I looked into it as soon as I got my ass home. Thanks, I wouldnt have seen it unless you told me what it was. I juts wanted to know what parts I needed. I had it fixed the other day, and all togather it was 100$. Too much money wasted on having some guy put it on because I dont know how to!
Originally posted by C.K. James
[B]
Yea, I looked into it as soon as I got my ass home. Thanks, I wouldnt have seen it unless you told me what it was. I juts wanted to know what parts I needed. I had it fixed the other day, and all togather it was 100$. Too much money wasted on having some guy put it on because I dont know how to! [/B]
[SIZE=3]DOOD!!![/SIZE]
If you wanted it done that bad you should have gave me a call, me and the guys hang out all the time and I would have changed it for you for lunch…next time, dont hesitate to call. :smiley:
