like the titile said i dont have hazard light and signal lights on all front and back.i checc all the fuses already.what else do i have to checc???thnks
You will need to check your hazard switch, power for both the hazards and signal lights go through the hazard switch, in fact the hazard power loops through the switch a second time, [when hazards are on].
You will need a multimeter or test light to check the wiring at the hazard switch.
The white/green lead, [hazard power] should be hot at all times.
The yellow/red or just yellow, [signal light power] should be hot when ign. switch is in run position.
If both are good check the green/white lead, [output to “Turn Signal/Hazard Relay”] should be hot when ign. switch is in run or hazard switch is on.:stare:94
