i know its fairly easy as people say but im getting hard time taking off the bulb and dont know what to connect what.
just a little help on how you people with hid kit installed it please. Thanks.
when i installed mine, it was pretty difficult to get the old bulbs out at first because the connectors were stuck on. but its fairly straight forward. first thing, determine where you want to mount the ballasts. those are the metal boxes. keep them fairly close to the headlights because the length of wiring varies on some kits. make sure they are secure, because you dont want them to bounce around at all.
the next step is putting the bulbs in. you do this just like any other bulb. once the bulb is in you can connect the wiring. its pretty idiot proof, in that they can only go one way. as seen in the above picture, you have a male and female connector. there will be a male and female connector on the end of the hid bulb. im sure you know how sex works. male-female, female-male. once this is done there should be a connector that has 2 or 3 wires on it, depending on whether you got a single beam or dual beam kit. this is the blue plug in the pic below.
the blue plug on the end of it plugs into your factory headlight connector. the other end of it plugs into the other connector on the ballast.
once this is done, make sure all the wiring is secure, and away from moving parts. i.e. belts (on the drivers side). after that, turn the headlights on, and cruise.
thanks i got it, just that when taking out the bulbs? did u just pull it out with force? cuz i dont wanna mess anything up lol
if you look at the base of the bulb, there are three notches cut out. the bulb can only go in one way. when removing the hid bulbs, you have the be very careful that you don’t hit it against the headlight housing and break the element on the bulb. you have to give it a good tug though because there is an o-ring that seals it from moister and it can be stubborn. i put one hand on the back of the bulb, and pull with the other so that it doesn’t come out fast.
