hey everyone for some reason my gas tank lid doesnt lock, i notice in the inside there is no lock or clip that the tank lid can catch to lock. I went to the scrap yard to see if i can take one but wasnt too sure how to remove it. Someone help please!!!
its tucked under the seats and carpet its real easy just follow the line and it unclips from the front were you open it by your seat
If you remove the panel inside your trunk (just about where your antenna is), you’ll have access to where the cable runs, and you can just stick the end of it through the hole. If you’re having the same problem I’m having (one of the plastic clips on the release cable that hold it into place broke), you’ll need to replace the cable, unless you can rig something up
you just turn/twist it out.
