Help!! Question!!
Okay so i recently bought a 92 gsr with original b17a1…i also have a 91 teg with stock b18a1 and i took off the dc headers off the 91 teg and stock headers of the gsr and wanted to switch em up but i found out the dc headers are shorter than stock 92 gsr…what kind of mods can i do to make the shorter ones fit on the gsr and the longer ones fit on the 91 gs? PLEASE HELP!!!
Extend exhaust a couple inches. I would just get a 92+ header because the o2 sensor would be in the right spot.
90-91 exhaust is different than 92-93 exhaust as you now know. making them fit each other is really easy actually. living in stupid california your options are limited but the easiest method would be to get a test pipe and get it cut or lengthened to fill the gap made on each car. living in california leave you no options other than buying another set of headers or leaving your cars the way they are…
i suggest leaving your cars the way they are…
also, this is in the wrong section…
