Help Quick please, ty
Hi, i have been reading and trying for an hour now, i have a gen.2 Integra RS 4dr… my passenger door lock doesnt work, like… when life it up to unlock it it goes right back down, so u have to lift the hell out of it and open the door to get it to open, and its a bitch so im trying to get the door pannel off so i can look in and find out wats wrong…
i have all the skrews off, and all the little poppys are done, the top bottom and sides all pull out so i can see in… but the window crank, or in that area… just wont come off and idk what to do… i tryed the t-shirt thing and it nvr popped out or anything… any help would be aprichiated cuz i need to get movin and run some errands within a couple hours and dont wanna have to put it all back in yet… thanks a lot!
ok i wasnt using a think enough t-shirt so i was missing the clip, i got the panel off but i still cant see whats wrong with the lock… the lock itself on that metal rod is loose and just fell limp when the panel came off… ne ideas? is there a specific area i should take a picture of for more help? thanks
http://www.g2ic.com/forums/announcement.php?f=32&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
