Help: Rear winshield wiper issue.
How do I fill my rear windshield wiper reservoir?
I’ve looked around but can’t find anything.
I don’t have a manual & I could find it in the Teg Tips.
Thanks in advance.
Rear washer uses the same reservoir as the front.
Thats what I thought, but for some reason my rear washer doesn’t get ant fluid.
I guess I have to dig deeper to diagnose this problem.
Thanks torralba.
it takes a few seconds before the water actually hits the rear nozzle as well - try and hold the rear wiper spray (separate switch than the fronts) and it should come on after a few seconds…
Also check for any leaks in the hose / breaks - mine was broken in a place or two under the hood and needed to be replaced…
check to see if the sprayer is clogged. use a safety pin.
