HELP! Removal of Rear Seats
Hey guys, how do I remove my rear seats? I need to remove them to clean them…thanx in advance for the help
removing seats…
hey elusive teg,
rear seats are a piece of cake.first fold them down.remove the plugs at the bottom that hold the carpet to the back of the seat.you’ll see three brackets that have two 10mm bolts each.remove all 6 bolts and remove the left seat (the smaller of the two seats). there is a bolt that goes through a bracket in the center of the seats, remove this bolt to release the right seat(slide seat to the right, then pull forward. the seat part is held by one bolt in the back.remove it then lift the back of the seat toward you.
this is the procedure for my 91 ls should be the same for all g2’s
good luck
shawn:)
