I need to remove rear seat in order to intall new oem carpet. Pictures would help alot. Search but no luck. There was one search but no pictures. Can anybody help me? Both seats are out and removed everything in the center.
easiest way it to remove the 2 backrests with the bolts behind the seats then you will see one bolt in the center of the bottom seat take that out and it should slide to you a little bit and out
