Hey guys, after going thru a big bump, my speakers will not work. The headunit works perfectly. Everything lights up and the cd player plays. I checked my wiring and everything looks good. I can’t tell what it could be. How can it knock out all my speakers at once…the front and rear ones don’t work at all. Someone help me!!!
are they stock speakers are they running through an amp…if they are i would check the ground wire thats happened to my bro before…other than that i would check the speaker connections…
later,
Dan ![]()
they are aftermarket speakers but they are not hooked up to an amp…i’m going to check the ground right now but I doubt thats the problem because the deck works fine.
When you looked at your wiring you didn’t happen to switch around the wires did you? If you have something crossed it’ll shut down your front and rear speakers, but anything hooked up to an amp will still work (ie subwoofer).
have to tried messing with your fuses? sometimes those things aren’t actually blown. This happened to me, I pulled 2 fuse out and swapped them and everything worked fine (maybe jsut dirty or lost it’s contact point).
HTH
Ken
