HELP SPECS ON JG 301 valve adjustment
just need the feeler gauge specs on these JG 301 cams…plus i noticed some valve lashing on my internal sidewalls…is this badd? and did i mention these cams shot out my rocker arm right straight through the back of the head…A VERRY NICE BIGGO WHOLE na mean!!~
Just adjust them to stock specs and you will be fine. I am running the same cams…
Later,
BR
I have the same cams in my car and the correct
valve lashing is .007 intake and .009 exhaust.
These specs are according to JG Engine Dynamics.
If you have JG cam gears then the settings are +2 intake
and -2 exhaust.
i’ve been running my jg cams at +4, -4 think there will be any bad effects? i idle is lumpy but not bad by my standards
john
Originally posted by snakeyes3460
[B]i’ve been running my jg cams at +4, -4 think there will be any bad effects? i idle is lumpy but not bad by my standards
john [/B]
You will be fine with that setting. I was running mine at the same settings as you for a long time and the only problem I had was idle.
Later,
BR
thanks this helps a whole lot…
why does these cams jg 301’s give such a bad idle?
They dont, as long as you have your cam gears set to 0. The further you adjust your cam gears the worse the idle will get…
Later,
BR
