Help Tail light fuse keeps burning out
In the last month my tail light fuse has burned out 3 times, just wondering if anyone has had the same problem before.
do you have aftermarket tails, or are they leaking/do they have condensation?
My friend’s GS-R has altezzas… water would get into them and short everything out, resulting in blown fuses.
Ya, only reason you would have fuses pop is you are grounding out one way or another, check your wiring for exposed wires in the back as well as the insides of the lights for moisture.
Have you installed an aftermarket HU, if so, make sure that if the HU did not use the illumination wire on the OEM radio harness, that that wire is capped off, if it shorts out it will blow the parklight fuse, [taillights] :idea: 94
