HELP: Troubleshooting window that won't open.
Hey guys,
Sometime over the winter my driver side window stopped functioning. My passenger side window switch still works, but the driver side won’t budge. I have the small leak at the top of my window that comes from the window not getting a good seal on the door, but it’s not like water has ever been pouring in.
It hasn’t been that warm yet in ohio, but it’s going to get warm soon and I really don’t want to be stuck without being able to open my window!
I figured I’d change the fuse to see if that was the issue, but I don’t have the fuse panel cover to show what fuse is the correct one to change (bought my car used from some asshole), so if anyone could tell me which one it is I’d appreciate it.
(I’ve searched and could only find threads about window adjustment which is another project for another day)
I’ll try and take a picture of mine for u. U have a da or db?
Thanks so much man.
I have a DA.
No problem, good luck. Da’s pwn.
while holding the switch down, try giving the door a couple good punches around the regulator. sometimes the brushes inside the motor get dirty and jarring it can be enough to get it going again. happened to me when i bought my DA.
funny thing is, before i’d bought it, it had been sitting out for the winter with the window half down, thus ruining the carpet. gave it one good punch and voila, up she went.
if you do get it to work this way though, you should change the regulator when you have a chance. otherwise it stay stuck open during monsoon season. murphy’s law.
